2001 Eddie Bauer Rust
Discussion in 'How To Section' started by cobalt46, May 7, 2018.
  1. cobalt46
    cobalt46 New Member
    Jan 21, 2016
    Indianapolis
    I have a 2001 fully loaded green expy. It has everything and I don't want to give it up. It runs great. But there is a problem: On a quiet night you can hear stuff underneath rust. What to do? I have first been brushing off loose rust then spraying it with Rusty Metal Primer. After 1.5 hours as said on the can I then apply a coat of enamel paint. After it dries i cover it with clearcoat. Is there a better way to do this and if so, how. The left rokker panel is already gone and I need to treat the rusty rear control arms. I need to stop this beautiful beast from rusting away. Any advice would be appreciate. Thanks
  2. MrSticker
    MrSticker Full Access Members
    418
    149
    May 4, 2016
    Penfield, New York
    Since you're in Indiana ... you might be hearing the corn grow! Let the Expy go, start getting ready to move on. Your Expy is like Marie Osmond, no amount of plastic surgery is going to fix the situation. Sorry Marie.
  3. johnboneske
    johnboneske Full Access Members
    344
    27
    Mar 30, 2010
    Columbus Ohio
    Don't laugh...but being from Wisconsin originally... In the dead of summer on a hot day around 85 to 90 with a fairly high humidity, you CAN hear corn grow!
  4. Eric08
    Eric08 Member
    30
    20
    May 23, 2018
    Kentucky
    I’m going through the same thing at the moment. I went to Walmart and got a cheap drill and wire wheel, spent a lot of time taking the rust off the bottom and after all metal places were metal again and not surface rust I painted back over it with rustolem primer and then rustolem black paint
Share This Page
