Bigbrown1998
2003 Expedition. I have been reading prior threads to try and fix this issue. A while back the truck would not shift into Park. I had to drop it to N to crank it. Through research I looked under the truck and noticed the shift cable had started to fray and come apart. I have installed the new cable from the dealership. Still will not go into Park. Seems as if the cable is too short to reach park. When the cable is not connected, I can shift it into park by hand at the tranny.
I have check the torx screws as well and they are fine.
Any suggestions? Can the shift cable be adjusted somehow? I am at a lost. Thanks.
