R W Carpenter
So, awhile back I bought the above referenced vehicle. It is sound mechanically but has two "convenience" issues that I would like to resolve. I will post seperate posts for each issue. Here is the second:
The truck is equipped with the Easy Exit Drivers Seat. When I scroll to the setting on the instrument panel, it at first indicates that the option is set to on but if you wait a second another item comes up that says Easy Exit Seat Data Error or something similar. When I turn the truck off and take the key out of the ignition the seat does not move back to the Easy Exit position. All other power functions on the seat work and the memory functions work as they should.
Has anyone else had this issue and been able to successfully resolve it? If so what did you have to do. I understand that I could set one of the memory buttons to where I want the seat when I am driving and set the other so that it slides the seat back but I would like the Easy Exit Seat function to work as it is supposed to.
Any help that anyone can provide would be greatly appreciated.
