2006 King Ranch
Bedrck47
Elizebethtown, PA
So what have you done to it are going to do to it Maybe time for some maintenance like new plugs fuel filter check for vacuum leaks
You need to provide better details other than saying "Truck is running rough"
D
dano100
Arden, NC
I'm working on it. Plugs have 60K Hwy miles on them, same with fuel filter. When I had the tuneup before, I replaced the #3 coil pack. Looks like I'm ready for more of the same. I now understand this "coil pack" issue can be a source of the problem. Now, I just have to decide whether I go to the dealer or not
Bedrck47
Elizebethtown, PA
If you have a CEL have the codes read and post them and if your just replacing plugs make sure you replace the boots also.
Bedrck47
Elizebethtown, PA
Glad you figured it out When you install new boots use some dielectric grease on the inside of the boot
Also make sure you torque the plugs to the proper spec
