2007 Ford Expedition EL will not start
N
Nathan
Ohio
Gotta get a jack to get my gut under the exp but the 30AMP fuse 40 was blown and a replacement made no change.
Bedrck47
Elizebethtown, PA
Sounds like a bad starter
There is a in-line connector C1026
Trace the wire from the starter back to the fuse box and disconnect that connector Then try turning to the start position and check the voltage at C1026.
Bedrck47
Elizebethtown, PA
If you replace the starter you may want to consider replacing the relay as the contacts most likely have been burned
Adieu
SoCal
BEFORE ALL THAT:
Pop trunk
Look on driver side rear trim panel (trunk area/behind third row)
Pry off the trim panel marked "Fuel Reset"
Press and hold switch inside for several seconds
Try starting the truck
Bedrck47
Elizebethtown, PA
BEFORE ALL THAT:
Pop trunk
Really????? Did you read this thread His problem isn't fuel related It a problem with the starter motor
Adieu
SoCal
Yeah I thought mine was a battery problem or a starter problem too...sure SOUNDED like it
Btw thats not a "fuel problem", it's a fuel cutoff that cuts off fuel flow and/or pump.... it engages if certain sensors get tripped and the truck thinks it might've got hit....and/or when you mess with electricals....who knows, it just HAPPENS. Generally after replacing something
ANYWAY.... It takes 30 seconds, it works when you least expect it to work, and it beats standing around stranded or throwing money at a problem that MIGHT not exist
stamp11127
Temple, Georgia
Please explain how "messing with electricals" will trip an inertia switch that only has 2 wires.
Even if it was tripped the switch cuts power to the fuel pump not the starter.
