2007 small oil leak leak front passenger side of engine
Habbibie
Is it Christmas yet?
Chicago
well, I was under the impression that the oil pans were unlikely to leak on these, but thats what it looks like mine is. as far as oil pans go on newer vehicles, this doesnt look like it will be too awful
The cross member has to be removed. It's a much bigger and time consuming job than you think bro. If you don't have a lift or sitting high on stands you're gonna have a nightmare replacing it
D
DD31
Ft Wayne, IN
Haha. Thanks for the heads up. I've got to drop the front diff too. Looks like I've got to maneuver around the rack also. Compared to other vehicles I've done, this looks pretty easy.
I do need to grab a factory service manual from somewhere.
rjdelp7
2000 XLT
NY
You can try tightening the bolts on the pan, first. 14-16ftlbs. I had some old Dodges and Chevys, with oil pan, seepage(never a Ford). I found the bolts, were not that tight. The oil pan, only catches oil, it is not under pressure. A bad PCV, lets gases build up and could cause a leak, or make it worse. Does your oil, smell like fuel? Excess piston blow-by, could cause the crankcase to overpressure. It will leak at the rear and front main seals. Replace the PCV and try leaving the dipstick out a hair. It will work like a vent. A blocked exhaust and over filling, with oil, will also cause a overpressure.
max357
