StephanSloan
Hi all-
I've enjoyed reading the threads here and would like suggestions on a 2008 Expedition EL 4x4 Limited with 144,000 miles. It has been a great truck for us but it is time for brakes, shocks and anything else that will help tighten up the ride.
I am also considering using the truck for some horse trailer towing. Short distances and less than once per month but the trailer plus horses will likely weigh 5,000-5,800 lbs. I have the towing package with 7 pin connection.
From reviewing the posts I'm interested in advice on the following:
1- Replacing spark plugs (Should I attempt or is this a job for the dealership?)
2- Installing a transmission fluid temp gauge and transmission fluid flush/change.
3- What do you all recommend for brake rotors and pads? Is this kit recommended? https://www.rockauto.com/en/moreinfo.php?pk=4496547&cc=1440071&jsn=456 I am also looking at https://www.rockauto.com/en/moreinfo.php?pk=7575016&cc=1440071&jsn=465 but am not sure the extra $$$ for the new calipers is a big step up?
4- Replace the struts. I am considering https://www.rockauto.com/en/moreinfo.php?pk=7344188&cc=1440071&jsn=496 Is there value in the strut/coil combo or would I be ok with front and rear https://www.rockauto.com/en/moreinfo.php?pk=1532028&cc=1440071&jsn=515
5- Are any suspension kits worth it? I see https://www.rockauto.com/en/moreinfo.php?pk=5734785&cc=1440071&jsn=520
Before reading the posts here I had not considered a tuner or a cold air intake. I'm impressed with the comments about improvements with programs to adjust shift points. Should this be on my list and is there any benefit to the cold air kits if I don't do any other modifications to the throttle body or exhaust?
I recognize that I will quickly spend more $$$ than I will get back in value in the truck but want the capability and to have a good vehicle. Also, new ones are $50+k so that will have to wait a while.
I know I am asking a lot and appreciate any guidance you offer.
Best,
Stephan
Best,
Stephan
