2012 expey INTERIOR COURTESY MAP LIGHT
Discussion in '3rd Gen - 2007 - 2017' started by Maleficent, Sep 13, 2017.
  1. Maleficent
    Maleficent Member
    45
    Sep 12, 2017
    California
    need help with a light issue. I changed out my bulbs to LED. my passenger side, 2nd row light does not work at all. any suggestions?
  2. ExpeditionAndy
    ExpeditionAndy Supporting Member Supporting Member
    59
    1,937
    325
    Aug 31, 2013
    Fort Wayne, Indiana
    Welcome to the forum. Turn your bulb around they are polarity sensitive.
  3. Hayes Riviere
    Hayes Riviere Full Access Members
    20
    88
    25
    May 14, 2017
    Los Angeles
    Where'd you get the LEDs? Are they generic or made specifically for the Expedition? Thinking of doing an interior LED conversion in mine.
  4. Adieu
    Adieu Full Access Members
    31
    695
    82
    Dec 22, 2016
    SoCal
    Amazon $12 will do the trick
  5. Maleficent
    Maleficent Member
    45
    Sep 12, 2017
    California
    thanks Andy, but I am aware of the polarity of the bulbs. I am leaning towards it being an issue with the contacts on the assemply
  6. Maleficent
    Maleficent Member
    45
    Sep 12, 2017
    California
    Hayes, I got the LED set from Ebay, let me know if you need the info. The company I deal with is super professional.
  7. ExpeditionAndy
    59
    1,937
    325
    Aug 31, 2013
    Fort Wayne, Indiana
    Did the incandescent bulb work? Or is this something that occurred after the switch?
  8. Maleficent
    Maleficent Member
    45
    Sep 12, 2017
    California
    Andy,
    yes, the incandescent bulbs worked before the change
    the LED bulb works in the other locations, so I know it's not the bulb.
    I also tested the wires/connectors
    the issue began after the switch.
    all other lights work, For this reason I am guessing it's the assembly and the contacts.
    thanks for continuing to walk me through
  9. ExpeditionAndy
    59
    1,937
    325
    Aug 31, 2013
    Fort Wayne, Indiana
    Pull the whole housing out of the headliner and check the wires on the back side to make sure the plug is still connected. In addition use a volt meter to check the voltage at the connections in the socket and on the back side.
  10. Flexpedition
    Flexpedition Full Access Members
    408
    77
    May 26, 2015
    midwest
    You should have a constant 12V source when the key is ON as well as a switched 12V source, such as when a door is opened or key switched to OFF. And a ground.
    Swapping the known-working 2nd row drivers side with the now-dead 2nd row passenger side will tell you if the trouble is inside the assembly or not. Proceed from there.
Share This Page
