feelthemusic8
My Low Beam headlights will not turn on at all on my 2015 Expedition.
- High Beam headlights work normally
- Fog Lamps work normally
- Problem occurs on all headlamp settings, auto lamp, fogs on and off, etc
- Problem occurs on both right and left lamps
- Headlamps are plug and play HID high and low bulbs
So far I have done these steps in this order:
- Changed bulbs to new HIDs
- Changed ballasts to new ballasts
- Checked both left and right fuses for low beams (they were fine)
- Changed both fuses with new fuses
- Removed Low beam HIDs on both sides and replaced with the original factory Bulbs (Halogen)
- Replaced Entire Headlamp switch on the lower dash
- Replaced Multi Function Switch on the Steering Column
After all this, I still have no working low beam headlights. At this point, I have the stock halogen bulbs, all new switches and fuses. I have also checked all wiring and connectors at and near each of these parts and everything looks normal with no corrosion, melting etc. Also have no other electrical issues in the vehicle.
The only other related thing that seems like it could have been related is that I originally noticed the problem, but if I switched the headlights off and back on a few times, they would come on. After I changed my battery recently, that trick no longer worked.
Any ideas?
Any ideas?
