So the wife and I are on the fence between the short and long wheelbase. It wouldn't be often we would have the seatin at capacity with luggage but it will happen at least a couple times a year. Can anyone here that has had an Expedition already comment on their particular wheelbase option likes/dislikes and wishes? Thanks!
Know people with both and have family with both and if you carry a lot of gear the EL is going to be better for you no ifs and or buts. There isn't much room in mine when all the seating is up where as in the EL there is an adequate amount. If you will be taking it in rough terrain or sharp hills standard length is better as it won't get hung up as easily over the too long wheelbase of the EL. For 2018 it will be called MAX I believe but I think the wheelbase will be closer to standard now. It's also easy to parallel park mine (if a chevy cobalt can fit there, I can fit there, well in my mind I can).Where as with the EL or Max this is not the case. My standard length isn't much longer than a sedan.
