david.bell.9678
- Joined
- Nov 27, 2014
- Posts
- 4
- Reaction score
- 0
Hello.
I did a Forum search and could not find info so I put in Electrical rather than Towing.
2012 Ford Expedition XLT. It has a standard 4 pin flat connector that is OEM.
Two weeks ago I could not get the trailer rear and marker lights to work. The left and right turn signal both worked, just no marker lights. In checking the 4 pin flat mounted on the Expy I noticed the little metal sleeve inside the connector for the TM pin had been pulled out. The right and left turn signal still worked.
I could not find a sleeve to fit in the connector so I purchased a new 4 pin flat and cut off the OEM connector. I have everything wired up correctly. I get left and right turn signals on the trailer but no trailer rear and marker lights.
Since all of the Expy’s lights work properly it appears to not be a fuse related to the vehicle. Does anyone know if there is a separate fuse that is for the 4 pin wiring harness? The wires have never been messed with and are in their original wiring loom so I don’t think the single TM wire being nicked or severed is the issue.
Any ideas on where to go from here?
Thanks,
Dave
Thanks,
Dave
