USMCBuckWild
Ladies and Gentlemen, I call upon you to sanity check my newest crackpot scheme.
I have a utility trailer that gets a decent amount of use between myself and my neighbors. It has LED lights throughout with reverse light capable tail lights, but the reverse wiring is not run since it is a 4 pin connector. Now, I like to be able to see when I back up and want to utilize the installed reverse lights. Just swap the connector for the 7pin, right? Not so simple. Majority of the neighbors (most are older) only have a 4 pin connector.
So, my plan is to purchase one of these:
https://www.amazon.com/Lavolta-Trai...078079&sr=8-2&keywords=7+pin+trailer+junction
Install it and run the stock 4 pin connector to the appropriate pins. Now I understand wiring like this will backfeed the 7pin plug, and that should not be an issue as it will be properly capped to avoid any shorting. This will leave me with a 7 pin with active reverse lights for those who have that plug as well as a 4 pin for those who only have the 4 pin.
I have thought about just wiring it up with the 7 pin and getting a 7/4 adapter. Problem here is if one of the neighbors "drops" it or it stops working/wiggles loose (have had this happen to me) they will be stranded or possibly at fault in an accident.
What says those who are smarter than I?
