4x4 WONT ENGAGE
Discussion in 'Transmission & Drive train' started by gregc729, Feb 6, 2013.
  1. gregc729
    gregc729 Member
    Dec 6, 2012
    florida
    Ok guys I had a friend do the the upper and lower ball joints and control arm on my 1999 for expedition XLT both sides...This was done about 2 months ago ...The other day I went to pull a stump out and was not able to engage the truck in to 4 wheel drive ... I hear no click when I turn the knob and the light dosnt come on in the dash window ... When I first start the truck the... 4x4 light comes on then go off ... Is there any thing I can look at before sending the truck to the shop Thanks Again Greg !!!!! :goofy_batman::goofy_batman::goofy_batman::goofy_batman::goofy_batman::goofy_batman::goofy_batman::goofy_batman::goofy_batman:
    tinkering likes this.
  2. tonydiv
    tonydiv technical advisor
    1,748
    127
    Sep 12, 2009
    Middle River, MD
    Most common cause is a bad transfer case shift motor.
  3. Flightstopper
    Flightstopper Well-Known Member
    47
    Mar 14, 2013
    Alabama
    Yep shift motor more than likely but check your vacumm lines first. May get lucky and have them unplugged
  4. Jeff532003
    Jeff532003 Full Access Members
    123
    13
    Mar 4, 2013
    Massachusetts
    I was thinking vacuum lines myself. Seeing as there's no noise detectable when you flick the switch I'd start there. If they're good then it's likely the shift motor as mentioned. Look for one online and you'll same some cash. Amazon and rock auto both carry them.
  5. gregc729
    gregc729 Member
    Dec 6, 2012
    florida
    ok guys just getting around to look at this now that we are heading some where that has snow .... Where can I find a diagram showing me the vacuum lines that would effect the 4x4 not to engage .... Thanks again Greg !!!!!
  6. bedrck46
    bedrck46 Guest
    would also check your fuses Check this post "yet more 4 wheel drive problems" there are prints there for a 97 but the wiring is the same for your 99. Could be a bad fuse or bad relays or a bad selector switch. At least check for power before you replace parts
  7. bedrck46
    bedrck46 Guest
    Also check the wiring to the wheel speed sensors. Being you had the ball joints and control arms replaced. I know when I replaced mine it does tend to put some stress on those wires if your not careful.
  8. jsawyer1181
    jsawyer1181 Member
    16
    Sep 5, 2013
    Henderson,NV
    Mine spontaneously stopped working a few months ago. It's on my fix it must. Prolly the shift motor.
  9. reefkrazy
    reefkrazy Full Access Members
    39
    231
    31
    Feb 19, 2013
    ct
    does anyone have a picture of the module behind the fuse box? I have same problem. Worked then nothing. I've tested the switch. I get 4v then 3v then 1v. Awd , 4h and 4l. no clicking, no lights. I opened the hood where the airlines go to hubs. Nothing there. Fuses are good. Does the power come from the shift motor?
  10. MEXMIGHTY
    MEXMIGHTY New Member
    Feb 24, 2016
    houston
    4x4 problem
    hey guys need some help! the other day I got into the exp and was on my way to the store when the 4x4 automatically kicked in. the dash light shows the 4x4 light but the knob was still in AWD. its a 1999 expedition. shes babyed all the time and is my daily driver. since I got it ive never used the 4x4. I don't really have to I'm in s texas. any help is greatly appreciated
Share This Page
