99 EB transmission and rear end.
Discussion in 'Transmission & Drive train' started by ASIANREDNECK, Oct 6, 2011.
  1. ASIANREDNECK
    ASIANREDNECK Member
    16
    Oct 6, 2011
    alaska
    I'm new to this site. totally confused about fords setup. I have a 99 Ford Expedition 2WD 5.4 Eddie Beaur edition. Anyone know what type of transmission comes on it? The car has 140k miles.
    Planning on a 4k mile road trip towing a 20ft trailer. So I'm going to have to do some serious maintenance . Any help would be appreciated
    Thanks
  2. dgna5
    dgna5 Member
    Sep 10, 2011
    New Mexico
    With 2WD most likely an E40D,
    1st. get a new overflow tank cap at 130K mine failed and entire cooling system failed,it needs correct pressure/venting. replace t-stat, (STAY OEM on T-Stat temp..),and then get the fluids changed, if you have time/$ change diff fluid also, my rear diff failed at 150ishK, a little extraordinary maint. esp. when towing is well worth the X-tra time/$!!!
  3. trdragons44
    trdragons44 Full Access Members
    28
    240
    Jul 15, 2007
    nj
    the e40d/4r100 comes with the 5.4 the 4r70w came with the 4.6 and since you have the 5.4 most likely you have the 4r100/e40d(same trans just new naming convention used)
  4. ASIANREDNECK
    ASIANREDNECK Member
    16
    Oct 6, 2011
    alaska
    do they make helper springs for expedition with air ride?
  5. ASIANREDNECK
    ASIANREDNECK Member
    16
    Oct 6, 2011
    alaska
    ok here is a picture of my suspension. I have springs and air suspension? [​IMG]
  6. ASIANREDNECK
    ASIANREDNECK Member
    16
    Oct 6, 2011
    alaska
    Does the e40d come with trans cooler?
    what type of transmission fluid do you guys recommend ? How many qrts do I need if I drain the torque converter and pan?
    Thanks
  7. trdragons44
    28
    240
    Jul 15, 2007
    nj
    Looks like you have regular spring suspension the air ride would have a airbag where the coil spring is. The trans cooler separate from the radiator is only there if you have the hd tow package<-consists of heavy duty radiator, 7-way trailer plug, drop hitch, trans cooler. if you look at the front of your truck there should be two little radiator looking things, if there is only one on the drivers side(power steering cooler) you do not have a secondary trans cooler. tranny fluid should be whats listed in the owners manual usually mercon and i believe it takes upwards of 18 quarts if you drain the TC. hope this helps
Share This Page
