99 expy stuck in 4x4 low.
that1guyb4u
Nebraska
I have a 99 expedition awd. It is stuck in low lock. I've tried unhooking battery, Backing up in neutral for. In Neutral with brake on. It doues not have the plunger on front axl, Nor can i find vacuum lines on firewall. I've been reading forums for a week. Also speedo is same as rpm's Also took out fuse 104 and put new in. Maybe bad shift motor or switch? Need help. anyone?
Bedrck47
Elizebethtown, PA
The 99 Doesn't use vacuum for the 4X4 system That was only on the 97/98 model years
Try checking fuses or the shift motor may be stuck
savbraze
