Hi,
I bought a set of ac gauges and hooked the up to the expy.
What should they read on a 01 ford with dual air?
What is the low pressure side suppose to read?
What is the high pressure side suppose to read?
At 100 degrees outside and 60% humidity, the low reads 60 psi and the high side reads 250 psi...
I have the truck at idle when reading.
Shoul I adjust to 1500 rpm first?
Ambient presure is 125 on both sides.
Thanks if you know....
