Adding Rear 3rd Row Speakers
Discussion in 'Audio & Electronics' started by AndyGJ, Feb 1, 2010.
  1. GAIN-MOB
    GAIN-MOB Super Moderator Staff Member Supporting Member
    13,915
    727
    Yorktown, VA
    I can turn sub off...when I take trips I will have 2-12's...I don't want the 3rd row bassed out completely...the subs will be off or down real low so it'll work
    Sent from my BlackBerry 9810 using Tapatalk
  2. KINGDELL91
    KINGDELL91 Member
    18
    Jul 21, 2012
    I might look into the factory Pillars that he had pictured i love the placement of them i would just have to swap out the factory speakers. I also like the amps under the seats i might have to check if that will work for me before i install it in my rear panel cause i would really prefer to weld a battery rack in there
  3. GAIN-MOB
    13,915
    727
    Yorktown, VA
    I already have my amp in the rear panel...I was just thinking of how to put a battery back there
  4. KINGDELL91
    KINGDELL91 Member
    18
    Jul 21, 2012
    Im throwing my 4ch in there my DC 3.5k wont fit with i all that i have going on with it. but yeah get you some steel bars and weld it in there bro im just waiting to get money for new batts i had 3 HC 2400's going to switch to XS Power in rear and under hood. The one in the panel will always be there and there others i will move in and out as i please
  5. KINGDELL91
    KINGDELL91 Member
    18
    Jul 21, 2012
    nice where did you ground the amps?
  6. MauiBoy99
    MauiBoy99 New Member
    Mar 8, 2017
    Denton, TX USA
    For anyone interested, I'm doing this mod on my 2013 Expedition - add the OEM Lincoln speakers to the rear. The part numbers I got from the dealer for medium light stone colored trim (18978B) are:
    • 7L7Z-18978-DAB (LH $54.96)
    • 7L7Z-18978-CAB (RH $64.96)
  7. DD31
    DD31 Full Access Members
    52
    Mar 7, 2017
    Ft Wayne, IN
    Thanks for the part numbers. This seems like a good addition to the sound system
  8. Flexpedition
    Flexpedition Full Access Members
    360
    57
    May 26, 2015
    midwest
    Just want to make sure you know that these are the speakers ONLY.
    They require the d-pillar trim / housing / pod for the speakers to mount to. This is the same trim where your 3rd row seat belts mount to.
    Here are some example part numbers for those. They vary depending on standard/extended length and interior color.
    * 7L7Z-40310-11AA dealer list price $184.57 driver side
    * 7L7Z-40310-10AA dealer list price $182.85 passenger side
    Google random picture:
    [​IMG]
  9. MauiBoy99
    Mar 8, 2017
    Denton, TX USA
    Unfortunately, these are the speakers + grilles only, as I found out when they arrived. The actual "D" pillar trim is <31010 IIRC.
Share This Page
