Jeff Shinham
I have a 2006 Expedition that I'm having trouble with. I had some issues in the past,, The Throttle body / Throttle position sensor. So I took it to a friend of mine with a much better scanner than mine. He could see much more codes than I could. He mentioned that the 4x4 was throwing an error code. I didn't do anything about that because I rarely use the 4x4 (Automatic jack when changing the oil)
The other day the advancetrac light was going on and off, and I heard what sounded like the Transfer case kick in then out, the car lost power then came back to normal. ( rolling at about 35) I drove it home with the advancetrac off, When I got here I tried to restart the car. No electric at all.. In the direction of the fuse box I can hear a little clicking, but the only thing on the dash board that lights up is the airbag light,, and barley lights up at that. If I try it several times like taking the key out and starting over, sometimes it will start just fine.
I have been looking all over the car and the web for the Transfer case module, but can't seam to find it. I'm not sure if that is the problem or not.
I have also had some other electrical things go out like the interior lights only work when the door opens not on demand. The garage door opener stopped working about 2 years ago, and the passenger exterior courtesy light
I bought the car new and have driven it for 170K miles. I would like to make it to 200K if posible.
