kyle_in_rure
97 Expedition 4.6 EB.
yesterday I misread a fuse diagram and accidentally pulled the 10amp "airbag diagnostic monitor" in the fuse block in the engine compartment. (Boy I feel stupid now) Now wherever I go it flashes airbag code 52 and then will burn steady for a while.
I've done some searching for connector you can reset behind the passenger kick panel but this is the only connector I have found, and it has purple/pink and green wires instead of the tan/red and black that are mentioned in other articles. I'm not sure I'm comfortable shorting the two wires if I don't know what they're for.
I checked all airbag fuses. Is this something that will reset itself eventually or am I stuck with it ? The airbags aren't going to randomly deploy one day are they ?
