am I tripping, or does fog light use dent MPG??
Adieu
SoCal
I'm getting a strange suspicion that my LED fogs cost me ~1 - 1.5 mpg
Can that really be?
If true....what about 35w HID headlights, are those a significant drain?
And if a few dozen watts can actually cause visible MPG change, does that make radio a real drain too???
stamp11127
Temple, Georgia
Really?
You would need a bunch of super bright LEDs to cause the alternator to increase the amp output and load the engine more. Probably in the hundreds of them.
Find out the amp draw of the LEDs.
Watts / volts = amps
The 35w Hid will draw just under 3 amps while running with possibly a higher draw to start them.
Largest drain on the electrical system when running are the headlights (halogen), ac clutch and blower motors.
Habbibie
Is it Christmas yet?
Chicago
Well that's a first, your car is aging, parts are deteriorating and efficiency is reducing... I'd look somewhere else for that mpg drop... somewhere A LOT more obvious!
A
Adieu
SoCal
No, I meant I thought I observed a jump UP in MPG by turning off my LED fogs...
I think they draw ~4 amps (50w 12v) each if I'm not mistaken.
I can still pull off ~15mpg mostly city driving with heavy A/C use, that's very reasonable and close to the V8's efficiency ratings as-new afaik
bobmbx
Everything on everyone's car that uses power, either mechanical or electrical, puts a dent in the MPG. Headlights, AC blower, USB cellphone charging port, ....everything.
Is it significant? Some will hit it harder than others. Can you figure out the difference? Sure, but, why? My god, you own an Expedition. If the effect of the fog lights on your MPG costs you more than 2 seconds of sleep, I recommend you look into some sort of Japanese product.
A
Adieu
SoCal
Cause I bought it for $4600, not $55k?
rjdelp7
2000 XLT
NY
The defroster setting, engages the AC compressor. Driving around in that setting(when not needed), will kill gas mileage. You could have a brake caliper dragging. Put it in neutral, on a slight grade. Check if it rolls.
A
Adieu
SoCal
I don't have low gas mileage, it just SEEMS like it gets visibly better results if I turn everything but headlights off
Of course some of that might be other subconscious efforts to learn to drive more efficiently... but, really, how much more is up to the driver once he's in cruise control on open highway, not touching any pedals for miles??
rjdelp7
2000 XLT
NY
You gave up your right, to complain about gas mileage, when you purchased a Expedition...period.
A
Adieu
SoCal
I'm not complaining. I'm working on keeping it closer to 17 than 12 is all.... cause I've seen both numbers.
