gulfman
I keep getting the message to " Check Backup aid" when I put the transmission in reverse. I took it to my ford dealer and their computer got an error code C1983. They said I needed a new Parking Aid Module for $ 450.00. I said to forget it. I went to a salvage yard and tried 2 Parking Aid Modules. The numbers all matched with the original. It made no difference. The chances of 2 modules being bad is slim.
The Back Up Aid works fine when the temperature is 40 degrees or below. Above 40 degrees inside the vehicle, it then gives the same message "Check Backup Aid". Does anyone have any ideas what could be causing this problem?
Bob
Bob
