Hi guys, I'm a new member here, but have found lots of useful info on here in the past. I'm kind of stumped now and am looking for some help. I have a 2003 expedition Eddie Bauer. I was driving at highway speed in cruise control the other day. I tapped the brake pedal to shut off cruise and pass a car. When I hit the accelerator, the speedometer and tachometer both went way up, but I did not accelerate. It was like i was in neutral, and revving the engine, but the speedo went up as well. I coasted off the side of the road and came to a stop, while leaving the car in drive. I pushed the gas a little and it went forward, so I pulled back out onto the highway. It did in fact accelerate, but the speedo went up much faster than the speed I was actually going. I let off the gas and the tach and speedo went through the roof again, with no acceleration. I pulled off the side of the road again, this time I put it in park. I got out, checked the tranny fluid, it was good. Checked for leaks, found none. Grabbed the driveshaft, could not spin it. Put it in drive again and limped down the berm to the next exit ramp. Of course, when I let off the gas again approaching the stop sign at the end of the ramp, everything happened again. I coasted it backward and off the side of the road. This time when I put it in park and let my foot off the brake, it started to coast backwards. I called a tow truck, and he agreed to meet me at a parking lot about half mile from where I was at, to avoid having to get on and off the highway. I put the car in 4 wheel hi and drove to the lot. While I waited for the tow truck, I drove around the lot to see if maybe I could figure out a problem. It shifted fine through 2wd, 4hi, and 4lo. In any gear it would accelerate slowly, and the speedo would read much higher than it should. I heard no clunking or banging or grinding. After it got towed home, I messed around a little more in the driveway. These are the things I've noticed so far, and can't figure out. When I try to drive it, it drives like it's in 4lo, with the whine and jerkiness, but it is in fact in 2 wheel drive. I proved that in the yard. I can shift to 4hi and 4lo, and the transfer case does what it should, but acts like it's in 4lo. When shifting to reverse or drive from park, it lunges and almost drives through the brakes like the idle is high, but the tach reads as it should. Twice when I've put it in park it has drifted like it was in neutral, but that's not consistent as I've put it in park many times trying to diagnose the problem. There is no CEL on, and when hooked up to a scanner, no codes or pending codes are present. I don't know exactly what I'm looking for, and before I start taking stabs in the dark and start spending money on a transmission, or transfer case, id like to see if anyone out there has had these problems before. Sorry it's such a long post, but I tried to give as much detail as possible. Thanks in advance for your help.
