Best fuel additive for carbon deposit removal?
Discussion in 'Tech Info' started by timberwoof, Jan 21, 2012.
  1. Captain Morgan
    Captain Morgan Full Access Members
    618
    22
    May 22, 2012
    WA
    I'm with Tallsville. It's up to you how you spend your money and if fuel additives don't hurt the o-rings etc then so be it.
    Either 1) continued use will slowly undo the tarnish and buildup over time or 2) you will reach a point of no more benefit and pay for a placebo.
    I think if Lucas \ Berrymens \ Techron \ 3M \ Seafoam is used for 4 tanks of gas over 4 weeks then it may be time to fall back to the quarterly application schedule.
  2. 10K-Watts
    10K-Watts Super Moderator Staff Member Supporting Member
    13,754
    695
    Yorktown, VA
    I either didn't read directions all the way or just missed the schedule...
    Holy Rollerz Christian Car Club (HRC3) National Member
  3. Captain Morgan
    618
    22
    May 22, 2012
    WA
    Lucas Oil/5.25 oz. fuel treatment
    Features & Benefits
    Lucas upper cylinder lubricant fuel treatment is formulated for gasoline and diesel engines. It does not contain harmful solvents or alcohol. This product is a blend of heat resistant, super slick oils and additives with a high detergent action that cleans and lubricates the fuel system.
    • Causes fuel to burn more efficiently for greater fuel economy and fewer emissions
    • Negates the harmful effects of reformulated gasoline
    • Neutralizes the harmful effects of ultra low sulfur diesel fuel
    • Lubricates rings and cylinder walls for longer life
    • Cleans and lubricates carburetors, injectors, and valve seats
    • Eliminates need for higher octane fuel
    There's no hard rule on how often you use a fuel additive. If you think you're getting your money's worth and there's no harm or even additional benefits then it's a person choice.
    I scrub my stainless steel pots and pans with a baby powder paste to shine them up. Do I do this every single time I use a pot or pan? Nopers, but I do it occasionally and it's good for a while. Even if the fuel additive doesn't have any cleaning to do, in the case of Lucas it claims to lubricate the upper cylinder wall which is the same reason I like MMO.
    So no harm no foul.
    (no pun intended)
  4. sgtowing
    sgtowing Super Mod, Supporting Members Supporting Member
    5,507
    367
    Jan 30, 2011
    Valrico, Fl
    Hey Captain, how much they paying you for the endorsement. :happy175:
  5. Captain Morgan
    618
    22
    May 22, 2012
    WA
    Yeah really, I needs that check.
    I grew a beard to pay homage to Billy Banks
    and Chuck Norris
  6. Prospector
    Prospector New Member
    Aug 24, 2013
    Los Angeles
    Greased lightning, works great in my 72 Bronco too.
  7. BakerEdition
    BakerEdition EF Chaplain
    2,115
    53
    Aug 6, 2011
    I took the vacuum line of my brake booster and then started the truck and put the vacuum line in the bottle of Lucas sucked it down and then took it for a drive.....thought i was on fire for a minute....but couldn't find a mosquito for 3 blocks for days ....took it out on the freeway and opened it up...thinking about it now...i should have just shut it off and let that stuff sit for a while before blowing it out the back.
  8. thebuckaman
    thebuckaman Active Member
    27
    Dec 15, 2014
    il
    Kreen from KANO LABS
    Stuff works really well. Pour half in the crankcase (change oil in 500 miles- it will be BLACK from cleaning the engine internals) and half in the gas tank. I have had great luck with it on my camry and saturn. Changed the VC gasket on the camry when I bought it and it was pretty nasty under there. Did VC gasket again 15000 miles later and after one kreen treatment (500 miles and dump oil) and it was very clean under there. Also, you will notice your oil will stay golden for longer mileage on the dipstick after a Kreen cleaning.
  9. Summers22
    Summers22 Full Access Members
    54
    Sep 25, 2014
    Kansas
    Chevron Techron is what I use
  10. Gamecock
    Gamecock Full Access Members
    53
    Oct 8, 2015
    Canton, GA
Share This Page
