Can FORScan reset oil change indicator??
briandye
It wouldn’t be easy, but those odometer buttons are usually just a simple two-wire momentary switch.
I modify the 2006+ Crown Vic/Grand Marquis clusters with RGB LEDs and if it’s the base cluster (no message center, just the digital ODO display and single button) it would be simple to solder on a pair of wires to momentary switch wherever you wanted it. (But this involves removing the cluster, and opening it up - but sounds like you’ve done that before)
