Can't get 97 Expedition in gear. HELP!
Discussion in '1st Gen - 1997 - 2002' started by richlester, Jul 10, 2013.
  1. richlester
    richlester Member
    Jul 10, 2013
    Streetman, Texas
    The other day I was driving home from Academy Sports & My 1997 Ford Expedition (with automatic transmission) just suddenly stopped accellerating. The engine is running fine. But I cannot get it into gear. When I try to put it in Park, I hear gears grinding...... I checked the shift cable on both ends & it seems to be shifting properly. What else can it be? Has anyone else had this problem? Thanks in advance...
  2. FordandPolaris
    FordandPolaris Full Access Members
    2,247
    258
    Feb 7, 2012
    Saint Cloud, MN
    Do you get a blinking O/D Off light on the shifting stalk? Sounds to me like it might be rebuild time. I would bring it to a shop specializing in transmissions (if you don't have AAA, time to sign up, makes towing much cheaper in the long run) and have them take a look at it.
    I had a problem a year or so ago where my truck would not shift into drive, reverse and park both worked fine. Shop pulled the pan and shifting plunger, saw nothing wrong, put it back together with new filter and fluid, and it has worked fine since. Hopefully that's all it takes.
  3. Bowesmobile
    Bowesmobile Full Access Members
    397
    42
    Jul 7, 2012
    Clarkston, Mi
    Sounds like its time for a transmission rebuild. Something let loose in the trans. and is not allowing it to go into gear.
  4. richlester
    richlester Member
    Jul 10, 2013
    Streetman, Texas
    I dont get any flashing lights or anything. How much does it cost to have it rebuilt, if that's what I neeed?
  5. Bowesmobile
    397
    42
    Jul 7, 2012
    Clarkston, Mi
    Depending on the parts needed it can be anywhere from $1500 to $3500. Make sure whoever does it is competent. They answer all of your questions clearly and they have a good reputation. Or you can be going through the same hassle next year this time.
  6. Jay87LX
    Jay87LX Full Access Members
    527
    24
    Oct 2, 2011
    Cleveland oh
    These trucks as well as the F150 counterparts are so plentiful you can find used trans for $500
  7. richlester
    richlester Member
    Jul 10, 2013
    Streetman, Texas
    That's the route I'll go if I can't get her fixed.... Gonna change the Manual Lever Position Sensor to see if that helps....
  8. JUST4FUN
    JUST4FUN Admin Staff Member
    1,964
    60
    Oct 25, 2005
    Mokena Il
    If this is a 4x4 you might have a transfer case problem
  9. richlester
    richlester Member
    Jul 10, 2013
    Streetman, Texas
    It is a 4X4
  10. hortonguy
    hortonguy Member
    21
    May 9, 2013
    ohio
    dont waste your money on the trans range sensor your planetery gear set let go thats why it wont go into park and no flashing od light because it is a hard part not something that is electric or monitered by the pcm
Share This Page
