bigodub
Hello all, I have a 03 expedition with a 4.6 and getting code p0401. Now I have replaced parts in the egr system trying to get rid of the code but nothing has worked. I replaced the egr (aftermarket) dpfe ( Oem) egr solenoid, and have cleaned out the almost completely clogged egr ports behind the throttle body.
So having said that the truth still runs rough at idle almost like a bad coil. Once I pulled the vac line off or the egr valve the truck idle raises slightly and the idle is smooth. Just like I think it should run. I don't know why the egr solenoid is giving slight vacuum to the egr valve but it is. Is this my problem or something else? Please help thanks
