Bedrck47
If its the fuel tank pressure sensor You may not need to pull the tank The sensor may not be mounted to the tank Jack up the rear and remove the Drivers side rear tire so you can see up behind the tank look for the 3 wire harness and connector The sensor will be located in the hose coming from the tank However you may need to lower the tank a little to have some working room
At least that is how it is on my 04 And the parts stores don't show the correct sensor All I could ever find were the ones mounted in the tank
and I believe yours will be outside of the tank
