Check charge system
Discussion in 'Electrical' started by Chrisallen22, Feb 27, 2018.
  1. Chrisallen22
    Chrisallen22 Member
    36
    Feb 27, 2018
    Raymond illinios
    I have a 2003 ford expedition 5.4l it draining battery fully. What could be the causes of this. Has good battery and new alt. Looking for ideas to troubleshoot
  2. Bedrck47
    Bedrck47 Full Access Members
    5,641
    610
    Jul 4, 2014
    Elizebethtown, PA
  3. Bedrck47
    5,641
    610
    Jul 4, 2014
    Elizebethtown, PA
    Take a volt meter and put it across the battery terminals and post the following voltages
    Voltage with engine off and key out
    Voltage at idle
    Voltage with the engine running about 1200 to 1500 RPM's
  4. MrSticker
    MrSticker Full Access Members
    359
    135
    May 4, 2016
    Penfield, New York
    NEW alternator doesn't guarantee GOOD alternator
    I heard a whine coming from the engine compartment so I replaced the alternator. Turns out the whine was a serpentine belt pulley and the NEW alternator I put in was bad.
    Just a guess on my part but if you say the battery is being drained FULLY ... it sounds like something is not turning off and draining battery. I had that happen one time when the rear window wiper got corroded and stuck. It would not return to the home position, but kept trying - draining the battery. Check that! That was on my 2003 XLT and it has happened a few times but I'm onto it now so "the jig is up".
  5. Chrisallen22
    Chrisallen22 Member
    36
    Feb 27, 2018
    Raymond illinios
    Battery drained over night was parked
  6. MrSticker
    359
    135
    May 4, 2016
    Penfield, New York
    Bingo! That is the typical thing with that rear wiper problem. Mine did it when I parked in a remote snowmobile lot and came back couple days later after overnights to a dead battery.
  7. Chrisallen22
    Chrisallen22 Member
    36
    Feb 27, 2018
    Raymond illinios
    Do u know the voltage to it
  8. MrSticker
    359
    135
    May 4, 2016
    Penfield, New York
    No I don't ... the problem I refer to is fixed (on my Expy) by taking apart the rear wiper & cleaning/lubricating it - where it goes through the glass. Not sure if that's your problem or not.
    watch this video
  9. Bedrck47
    5,641
    610
    Jul 4, 2014
    Elizebethtown, PA
    Go back and read my post
    Do a parasitic draw test to be certain. That way you will know for SURE rather at guessing
    Although the problem may be the same Doesn't meant the cure is the same
    TEST THE CIRCUIT
    What happens if you take the time to check out something that someone says was their fix and then it doesn't solve your problem
  10. Bedrck47
    5,641
    610
    Jul 4, 2014
    Elizebethtown, PA
    That was the worst video I have ever seen
    At no time does he show how to hook up the meter nor does he even turn the meter on Or show how to do a drain test.
    Also on the second gen expys you can raise the lift gate window and turn the wiper by hand and it should move freely If it is stuck you will know right away.
    He even waits until everything is apart befor he tries to turn the operator
    And when he is finally done It was nice that he showed the wiper in operation.LOL
Share This Page
