If I can find some time tonight I'll go out and take a look see if I can locate it
Sent from my LG-G6 using Tapatalk
Thanks! I'm still waiting for my manual and my wife is threatening to take it to the shop...
lol just to make this whole thing more complicated...
The question remains: where is the coolant sensor!?
Juan214 I do agree with what you are posting However answer me this
How does the sensor that is mounted in the oil pan of the picture you posted show ENGINE COOLANT TEMP
That sensor can be used for oil or water temps when mounted in the oil pan it measures OIL TEMP BUT when mount in the Cylinder Head it gives coolant temp
PLEASE GO BACK AND READ POST#2 which gives the location of the coolant sensor
Right hand side just below rear of the Valve cover And being its a CYLINDER HEAD SENSOR that should tell you its mounted in the CYLINDER HEAD
Did see that on the second post, thought it was not found.
Post results.
I gave you some information earlier in this thread
Did you take the time to go and look to see if the sensor was where I stated??
