See if you can find a 2 wire connector in that area
This it what the manual has to say about getting to the CHT sensor
Removal and Installation
Remove the intake manifold. For additional information, refer to Section 303-01 .
Disconnect the Cylinder Head Temperature (CHT) sensor electrical connector.
Remove the CHT sensor and discard.
To install, tighten to 10 Nm (89 lb-in).
Coat the new CHT sensor threads with high temperature nickel anti-seize lubricant prior to installation.
To install, reverse the removal procedure.
If the wife does take it to the shop Make sure she asks them to let her know where it is located
So does this mean that the coolant sensor and the cylinder head sensor are the same thing? That's confusing because I found two different parts on Ford parts!?
And she's just dropped it off. I'll make sure she asks!
