Interesting! I'm currently showing a P0175 code - running rich on bank 2. Wonder if that's connected?Hi- No expert here but I had a similar problem with my 04. But I was getting coolant back by 3 & 4. It was a crack in one of the vacuum line fittings. Since your Expedition is older like mine, those lines get brittle and crack. Mine leaked and eventually was causing a code for a faulty ignition coil. It was basically drowning.
Not sure if this helps, but it's not a major repair, so hopefully it's the problem you're having. If not, best of luck.
Scott
I noticed a small pool of coolant on the top of my intake manifold between the #1 and #5 cylinders.
Does this mean I have a leak in the intake manifold? if so, what does that usually cost to fix?
