Dash switch question
deerhunter7979
Helena
It probably went to a set of auxiliary lights on the front of the vehicle. That is the most common and on that owners install
fe731as
Lost Wages, NV
My 03 E.B. 4×4 has a similar aftermarket switch as well. On mine, it is a "master" switch for a rear entertainment system that was installed by the original owner.
johnboneske
Ohio
Plati
Hey, I was serious about the eject thing????
It would be nice if there was a switch like that for regular vs premium gas, to select an engine tune that was optimized for the gasoline you are running in that tank. My 2002 Polaris snowmobile has something like that, you set the keyswitch for type of gas. Premium gas give you more horsepower but don't set it for that if you run regular gas or you can muck up things.
1955moose
A cut out switch for the exaust. On,wide open, closed, when you see the fuzz!
