Diesel Conversion ??
Discussion in 'Transmission & Drive train' started by Invictus, May 1, 2005.
  1. Invictus
    Invictus New Member
    May 1, 2005
    Indiana
    Would it be feasible to convert a 1999 Expedition to a Diesel Engine ?? Finding a donor would be no problem..
  2. monsta
    monsta Full Access Members
    49
    421
    Nov 2, 2003
    Big Island of Hawaii
    I doubt it but then again...deep pockets can do just about anything automotive.
    What engine were you thinking of swapping in?
  3. Invictus
    Invictus New Member
    May 1, 2005
    Indiana
    I was thinking about a Cummins Turbo Diesel..
  4. monsta
    49
    421
    Nov 2, 2003
    Too heavy and a tad bit too long, I would assume.
    A new front end would be in order. Not the body but the subframe and suspension.
    Would a compatible tranny even fit in the hump?
    I would say it would be easier to convert a Dodge QC into an SUV. Especially since in Mexico they have a Ramcharger that is based off the Ram reg cab, short bed.
    Hell, even stretching one of those would be easier! :D If you could get it...
  5. quakebuilder
    quakebuilder Active Member
    53
    26
    Apr 14, 2007
    SoCal High Dezert
    i have been toying with this idea for a few months now and i called an engine supply company to get an idea of weights. the 4.6 weighs 400lbs, the powerstroke 7.3 weighs in at 870! for transmissions options though i would prefer a stick and then swap in a dana 60/70 rear out of a superduty to get the speed sensor. i would think that a heavier front spring will definately be required for stock applications however since we are installing suspension systems in our Trophy Truck conversions the new longer/heavier coil would most likely work.
    has anyone else given this serious thought?
  6. green03
    green03 Full Access Members
    634
    Apr 28, 2006
    College Station, TX
    what about the 6 liter? with some good head studs they can make alot of power bone stock and hold up. i think it is a bit smaller and lighter.
    Matt R
  7. quakebuilder
    53
    26
    Apr 14, 2007
    SoCal High Dezert
    anyone know the size/weight difference? what trans goes behind it? what year was it offered?
  8. green03
    634
    Apr 28, 2006
    College Station, TX
    2005 diesel trucks for sure
  9. 737jet
    737jet Full Access Members
    39
    50
    Sep 6, 2006
    Vancouver BC, Canada
    I'm probably wrong about this but I'll give it a shot. My buddy was looking to get a 1997 f250 diesel. I never saw it, just read the add.
    Correct me if I'm wrong but wouldn't that front end/clip be the same as a 1997 f150? wich is the front end of an EXP?
  10. AvroAero
    AvroAero Full Access Members
    29
    526
    Mar 9, 2007
    Toronto, Ontario
    I'm not sure but that would end up being a 7.3 and thats a big old engine which I don't doubt is quite heavy.
Share This Page
