Butch Smith
Just started getting Door Ajar warnings. Tried the WD 40 but no luck. Is there a fuse that I can remove?
Thanks
Thanks
I am having the same problem with my expe. I have narrowed it down to the tailgate/rear window latch. I have tried spraying brake cleaner then followed it up with some pb blaster and once again with wd-40 and that fixes it temporarily.
One thing mine does you didn't mention is when the door ajar light comes on, usually the dome lights kick on also or the truck will not sense the doors are shut after we get out, so the lights stay on. I pull the small relay that is second from the top of the left column. However doing that you also disable your windows too.
