Door seals? Weather seal?
Ben_D
Metro Detroit
I bought a used '03 with 207,000miles... working through some issues... Both drivers side doors would rattle a bit... Especially the front drivers side. (bad enough that it would hurt my leg as it smacked into it.) I did the trick of stuffing tubing into the door seal and that made it much better... But I think in the long run I should completely replace the weather/door sealing gasket. What is this stuff properly called?
From a forum search someone mentions using 2004+ weather seal, implying it's better... Is Ford the best source for this stuff? Is it semi universal? Any dire mistakes I should avoid?
Also I wasn't sure if this should be posted in interior or exterior.
Thanks
-Ben
lbv150
Northeast
You may have to adjust the door lock mechanism to tighten the door rattle. Check that the door panels line up with each other and the body. Check the hinges for wear as well.
scoot0073
Georgia
A1 auto is only showing 97 - 02 for me too.. guess I'll look on eBay
Sent from my Pixel XL using Tapatalk
scoot0073
Georgia
I got the door rattle also..
cman1120
Colorado
I only can see up to 02 on their website too, my 06 could probably use some new seals. Also ill x3 on a little rattle, when going over bumps and such.
Sent from my SAMSUNG-SM-G890A using Tapatalk
scoot0073
Georgia
Ouch Ford told me $103 for just one door seal.. hahah
For that price I can live with it
