So this door started with a problem with the child safety lock. It wouldn't disengage so that you could open the door from the inside. You could only open the door from the outside. Now, the door will not open from the outside so it is just stuck shut and I can't do anything with it.
Do I need to remove the door panel somehow? Neither the inside or outside handles are floppy. All the linkage is still intact - I'm about 99% sure it's something to do with the child safety lock being stuck and it has restricted the movement of both of the handles.
