Dyno'd New Engine
devincox
Oklahoma
Last year I bought a long block from Modular Head Shop for my 97 EB 4wd. The stage 1, 5.4 with ported PI heads. I had a hard time finding someone to tune the engine. Nobody around Oklahoma wanted to purchase the equipment to tune the older fords with the SCT tuner. I finally found a guy, Bo at APS, and he tuned the engine for me this week.
Specs:
Mild-ish bullet cams
24lb inj
K&N cold air
99 stock expedition intake
BBK Ceramic coated 1 5/8" shorty headers
Gibson high flow cats and pipes
Gibson exhaust
It made 228HP / 345TQ to the wheels. Max torque happens at 3250rpms. The HP is a little lower than I expected (I figured it would be around 250HP) but the torque is right where I expected it to be.
I'm taking it get 4.56's next week and then some paint. It should be a decently responsive yet dependable ride once the 4.56 gears are in.
ExplorerTom
Colorado
You're putting down 2 less HP and 20 more TQ at the wheels than what the engine was rated for at the crankshaft.
Not bad.
rjdelp7
2000 XLT
NY
Why would you take time and spend money to "dyno" this motor? The 5.4l is not a HiPo motor, it is a work horse. 228hp is pathetic, for that displacement.
D
devincox
Oklahoma
I guess I should have titled it "Dyno Tuned new engine". You don't have to tune on a dyno but it safer and easier. I don't care about the HP numbers, I wanted some torque to haul a boat and for the truck to move more quickly when merging into traffic. Which with 345TQ to the rear wheels it does just that.
D
devincox
Oklahoma
I'm having a hard time deciding on 4.56 or 4.88 for the gears. I like to travel in this and not sure if 4.88's and 31" tires are a good fit for the highway.
ExplorerTom
Colorado
4.56s and 31s won't be good on the highway. I had 4.56s and 30s on my Explorer. It would leap away from a stoplight but going over 70 mph seemed like pushing it.
33s and 4.56 are pretty close to an effective ratio of 4.10. Is 4.30 available for your axles?
D
devincox
Oklahoma
I put some values in an rpm calculator:
3.73 @ 75mph = 2122 RPM
4.30 @ 75mph = 2400 RPM
4.56 @ 75mph = 2595 RPM
2595RPM's @ 75MPH is a little high.
reece146
ON, Canada
3.73s or 4.10s.
Take a look at what the rpms are when the trans is in direct drive for towing. I kinda hate towing with my Cherokee (32s and 4.56).
