Electrical issue no light, radio always on, and auto headlight not working
Crazy_moh
MN
The auto headlight, the inside light when I open the door not working and the radio will stay on after turning off the car and opening the door. My car is 2003 ed. Everything was working normal a night before that what I noticed so far. I checked the fues and all of them are good. I am thinking it might be the Gem contral. Any ideas?
Bedrck47
Elizebethtown, PA
your 03 expedition DOES NOT have a gem module
Sounds like the problem may be the door switch.
Can you read and understand electrical diagrams?
Do you have any electrical test equipment ie: DVM, Test Light?
Does this happen with all the doors or just one door?
Bedrck47
Elizebethtown, PA
with the engine running open each door and liftgate one at a time and see if you get the door ajar warning light appear in the instrument cluster
C
Crazy_moh
MN
Does this happen will all the doors or just one door?
I am not that good with the diagrams but maybe you can walk me through it. I have a test light and I can get a DMV but also I am not that good with it.
I checked all doors and lift gate NO ajar warning light.
Bedrck47
Elizebethtown, PA
bare with me on this
Make sure all doors are closed.
Start the expy then shut it down and remove the key
DO NOT open the doors but see if your windows operate after you shut if off and remove key
C
Crazy_moh
MN
I did the windows will stay operate after I remove the key.
I checked the fuses by the passenger side with test light.
