Hello everyone!!
I am having an issue with my 2006 expedition Eddie Bauer 4x4 that has just started happening recently. Whenever I start the engine it starts right up then the rpm keep slowing down til it stumbles and dies. When I try restarting it then it spins over and over with no start. I switch the key on and off a couple times then it starts right up most of the time and runs fine with no problem or drivability issues after that.
Here's what happened with it today....cranked it up to go to work fired right up back out of garage put in drive went about 100 ft engine died. Turned key to start engine spun over and over no start. Turned key on and of twice engine fired right up and drove to work (20 mi) no problem. Go back in it to go to lunch. Cranked right up ran fine. After lunch cranked right up then died. Turned key on and off, started right up. Went to leave work, cranked right up drove back home no problem. After sitting a couple hours got in it to go to town (4 mi) shut off to go in store. Came back out 10 min later started it up and it stumbled and died. Tried cranking without switching key off, spun over and over no crank. Turned key of and on couple times, started then stumbled and died again. Turned key on and off a couple more time then cranked, started right up and drove back home no problem. Any ideas, sorry for the long explanation. I know the more info the easier it is to help. Thanks for your help.
