DFendersExpy
Ok Kool
Engine and Tranny,
According to RCI and posts elsewhere, Engine and Tranny yes.
Transfer case for 131 WB no. Not sure about the 119 WB.
Nothing for the 131 fuel tank. But then that does not look available from Ford either.
As noted if your Expy did not come with skid plates on the fuel tank, you will need to replace the skid plate straps with the appropriate Ford straps. These have studs built in to bolt the skid plate onto.
I got my straps from White Bear Ford posted above. Waiting to burn down the fuel in the tank before changing out straps. I'm just going to get a local metal shop to fab a piece of sheet aluminum for that.
09 SSV, actually...no clue if stock or not though, seems to have a bit of a lift courtesy of the taxpayer so who knows what other mods they bolted on
Is the mechanical cooling fan a good oldskool design, or a weak point and potential source of trouble that was wisely addressed in newer builds?
