ForScan Tweaks - 2015+
Discussion in '3rd Gen - 2007 - 2017' started by LokiWolf, Apr 26, 2017.
  1. ExpeditionAndy
    ExpeditionAndy Supporting Member Supporting Member
    59
    3,403
    906
    Aug 31, 2013
    Fort Wayne, Indiana
    Thanks to whomever made this a sticky thread! :D
    Muddy Bean likes this.
  2. Muddy Bean
    Muddy Bean Full Access Members
    308
    166
    Oct 19, 2017
    I know this isn’t quite on track, but my dad has a 2015 fusion and he merely wants his lane change signals to be set to the full seven blinks...I did this on my Expedition without issue. Anyone know off the top of their heads the code line to change for the ‘15 fusion? If not I’ll drag my bum over to the ForScan forum and sift through it to find the line....
  3. 17LimitedExpy
    17LimitedExpy Full Access Members
    83
    28
    Jan 4, 2018
    TN
    Mustang and Expy share the same location, so suspect the Fusion will also...try:
    SCCM 724-01-01 xxxx x?xx xx
    Lane Change Turn Signal Flash:
    Change ? to: 0-3 1 Flash, 4-5 2 Flashes, 6-7 3 Flashes, 8-9 4 Flashes, A-B 5 Flashes, C-D 6 Flashes, E-F 7 Flashes
  4. Muddy Bean
    308
    166
    Oct 19, 2017
    Ok I’ll study that line.
    Thanks!
  5. Carl H
    Carl H Active Member
    31
    Sep 9, 2012
    Rapid City, SD
    Alright guys, I screwed something up in the wife's truck and she's mad about it. I was trying to turn the voice nav on (SYNC 3), and it didn't work. So when I changed the line back to the original digit, she is unable to hang up the phone when using CarPlay with the steering wheel controls.
    Fortunately, the truck is in the body shop getting the damage repaired and I have plenty of time to figure out a fix. Anybody have an idea of what could have gone wrong? I have not updated to the latest firmware if you need to know. Also, I was unable to reload the As Built because something went wonky somewhere.
  6. 17LimitedExpy
    83
    28
    Jan 4, 2018
    TN
    To clarify...you were trying to activate/enable the turn-by-turn directions voice guidance on the Sync 3?
  7. HockeyPuck99
    HockeyPuck99 Member
    Feb 6, 2018
    Frisco, TX
    Does anyone know if it is possible to add time to the auto running boards going back up when the doors are closed? For my 2017 Expedition EL Limited, I believe the default is 2 seconds after you shut the door the running boards go back up. I am curious if I can make that delay longer.
    I'll start searching the F150 forums but I figured I would see if anyone else with an Expedition has already done some research.
  8. flexitis
    flexitis Active Member
    22
    38
    13
    Oct 3, 2017
    US
    When CarPlay is running it goes through USB not Bluetooth so the steering wheel controls will not work.
    Sent from my LG-LS993 using Tapatalk
  9. flexitis
    22
    38
    13
    Oct 3, 2017
    US
    Also if by adding nav prompts you meant adding nav to SYNC 3 that came without it your only option is to buy a nav APIM.
    The hack to add nav to SYNC was only on SYNC 2 (my ford touch).
  10. ExpeditionAndy
    59
    3,403
    906
    Aug 31, 2013
    Fort Wayne, Indiana
    That is a good question. Wouldn't mind finding that out as well. Often I close the driver's door and by the time I open the passenger door the running board is on the way up and then it reverses and goes back down. So I would mind adding 1 or 2 seconds to it.
Share This Page
