Fuel Filter
Discussion in 'How To Section' started by Tom018, Feb 8, 2010.
  1. Tom018
    Tom018 Member
    Dec 28, 2009
    ohio
    I have been having a little hesitation and wanted to change the fuel filter to see if that was the casue. I bought the filter for my 05 EXp and climbed under it all ready to do this simple in line fuel filter change, but I cant find it.
    Anyone give me an idea where the 05 fuel filter is located, beside under the vehicle and somewhere on the fuel line. LOL:D
  2. Stoned06
    Stoned06 Full Access Members
    47
    997
    32
    Apr 2, 2008
    Milwaukee
    Driver's side right in front of the gas tank (right behind driver's door). There will be a cover with 2 bolts (or nuts) that needs to be removed. You'll see the fuel lines running under the cover, and the filter is under that. You will most likely need a FF removal tool to get the filter off, as I needed one on my '06.
  3. Tom018
    Tom018 Member
    Dec 28, 2009
    ohio
    Thanks I will give it a shot. Do I have to depreassurize the fuel line or anything?
  4. Stoned06
    47
    997
    32
    Apr 2, 2008
    Milwaukee
    I would take the filler cap off, and it's not a bad idea to disconnect the neg cable from the battery to be safe.
  5. Makdaddy
    Makdaddy Member
    21
    Oct 19, 2009
    illinois
    Make sure you have the correct filter
    My wife had the local oil change place replace the filter on our 04
    We were on our way to indy Saturday when we hit a pothole and the truck died
    Yep the line came off the damn filter.
    To make it worse the shop either put the wrong filter on or they jacked up the hose connector. everytime I put it back on it was loose and would or could pop off
    Had to have it towed to the shop at closing time.
    We will find out Monday what all happened.
    I was not a happy camper
  6. ELVATO
    ELVATO Super Mod Supporting Member
    2,637
    19
    Nov 25, 2006
    Orlando, FL
    Here's where it is on an 03. Mine is just a cover you pull on, no bolts. I didn't need a tool to remove my filter, just pushed in with finger tips, though it may be different on yours.
    http://expeditionforum.com/showthread.php?t=2994&highlight=fuel+filter
    Make sure you clip it all the way in. Not a pretty site when you turn the truck on, and you hearing the splashing of gas as it leaks out the connector. Should of known something was up when the Expy took more than 2 seconds to start...
  7. jimmyv13
    jimmyv13 Full Access Members
    89
    Sep 13, 2009
    Anyone do this on the newer 07 body style yet?
  8. RUFFSTUFF
    RUFFSTUFF Active Member
    48
    35
    Feb 6, 2006
    GEORGIA
    Anyone know the right size tool for the fuel filter removal?
  9. ELVATO
    2,637
    19
    Nov 25, 2006
    Orlando, FL
    Mine are just green clips you push in with your fingers to release, but I've heard of others needing the fuel line connector removers sold at auto parts stores. They're pretty cheap.
  10. nvycrmn
    nvycrmn Full Access Members
    1,631
    Feb 15, 2010
    Springville, IA
    yes, they are pretty cheap but they also break easy so be careful when using them. the tool is only a few bucks and it comes with 2 sizes so you should be good. at least this is how its done on my generation.
Share This Page
