Within the last year, I had my malfunctioning fuel pump replaced on my 2002 Expedition. I began having problems with fuel gauge only registering 3/4 with a full tank, however; my trip computer (console in head liner) was fairly accurate and the electronic odometer still worked, so I did not worry about running to empty. Although pump was under warranty, dealer wanted $400 to replace. Already paid $800 for new part and labor. So I chose to just watch odometer and trip computer to determine gas needs
I went to add gas yesterday. Tank was nearly empty and LOW FUEL light next to gauge was turned on. Trip computer indicated 7 miles to empty.
After I added gas, the fuel gauge remained on Empty with LOW FUEL light on although I had added 15 gallons. Trip computer indicated 243 miles to empty, which is close to normal considering mpg on vehicle. Trip Odometer on dash was visible and reset to zero.
After I drove for about 10 minutes the trip computer went blank and indicated a "C0" on screen for miles to empty. On board computer still indicated a Miles per gallon screen and the compass still works.
After shutting engine off and restarting, trip computer was visible, for about 2 minutes then "C0" code shows. Fuel Gauge and LOW FUEL indicator still on.
Anyone see this problem and got suggestions on what to check
Thanks
Thanks
