fuel pressure regulator
Discussion in 'How To Section' started by sykes2011, Jul 7, 2011.
  1. sykes2011
    sykes2011 New Member
    Jul 7, 2011
    Nebraska
    I am trying to figure out how to replace the fuel pressure regulator on my 2000 Ford Expedition 5.4L can anyone help me with how to do this?
  2. dj_mindframe_99
    dj_mindframe_99 Full Access Members
    202
    Aug 19, 2010
    rockwood, MI
    A round, chrome cylinder on the fuel rail about halfway back on the right side of the engine. If you plan to replace it, just know that they rarely go bad and you have to remove the whole fuelrail to get it off. Symptoms of a bad fuel pressure regulator are usually of getting TOO MUCH fuel in the combustion chamber. If youre not getting enough, its more than likely in the following order;
    fuel filter,fuel pump,fuel injectors,PCM
    this might also help a little bit as well, just make sure you READ IT, don't SKIM IT.
    http://ww2.justanswer.com/uploads/kennyz1963/2009-09-12_010346_Intake.pdf
  3. dj_mindframe_99
    202
    Aug 19, 2010
    rockwood, MI
    did this give you the information you needed?
    and did it fix your problem?
Share This Page
