fuel pump wiring diagram
Discussion in 'General Discussion' started by msturg, Aug 9, 2011.
  1. msturg
    msturg New Member
    Aug 9, 2011
    cincinnati
    Does anybody by chance have a wiring diagram for the plug going to the fuel pump? I'm not getting fuel pressure and can't hear the pump run, however I just replaced it last fall. I would like to make sure it's the actual pump before replacing it again, I'm worried that perhaps it is the non-serviceable relay 303 or some other component.
    I pulled the tank down some last night to get to the harness which has 4 wires. I tried testing every combination of them to see if I got 12V when the key was first turned to on but didn't have any luck. I would really like to know which wires I should really be checking before going in one direction or another.
    Thanks for your help, I used this site last time when I had to replace the pump when I found a great write up on how to. Thanks again for that.
  2. crowbar
    crowbar Member
    Feb 20, 2011
    Ma.
    fuel pump
    check your 30 amp fuse for anti theft under dash. make sure contacts are tight. my fuse was ok contact to panel was loose fuse needed a shim. My 2000 doesnt have anti theft but it has the fuse to disable the pump. its bundled with random elecs. good luck
  3. ELVATO
    ELVATO Super Mod Supporting Member
    2,637
    18
    Nov 25, 2006
    Orlando, FL
    What year?
  4. Rob123
    Rob123 New Member
    May 30, 2011
    Norway
    diagram for a 2003 Exp. :)
    • FP.pdf
      File size:
      45.2 KB
      1,268
Share This Page
