cdherman
AKFordGuy -- yes, for 2003, the only required parts are the seal and a new circlip. Thatbeing said -- you will have to remove the CV joint and hub to get the axel out. I replaced the top yoke and the bottom ball joint, steering ends and the rest of the suspension while I had it all appart. Not sure that I needed to, but I was converting from airbad to coil suspension too. You hgave to use a slide hammer or equivalent to "pop" the axel out, FYI
88Turbo -- 2001 is different. I have no idea what fixing the 2001 front dif entails, though I think you DO have to take off the diff cover and take some sort of clip out so that the axel will slide out. Perhaps your problem is that the clip in the dif is missing?
