HID Power from fusebox
Chewtoy
San Clemente, CA
Hi,
Am installing HID bulbs in my 2007, and they require a always on 12V connection for a relay. Would like to take power from the engine compartment fuse box. Can anyone suggest best location? Ideally, would like to use a connection that is separate from existing fuses. (an existing location that does not have a fuse installed. but has 12v available. I'm open to suggestions.
Thanks!
C
Chewtoy
San Clemente, CA
Found that all the large (square) relays in the fuse box in the engine compartment are powered. Add a fuse and a power out wire and it's good to go.
stamp11127
Temple, Georgia
The circuit should have 2 fuses, one for the control side and the other for the load (HID's).
