High idle
garyb6
westville nj
My 2000 ford expedition idles high when I start it up but goes down to normal after 15seconds..Help Pls [emoji13]
Sent from my SM-G550T1 using Tapatalk
MikeA
How high is your idle rpms and what is the lower idle rpms?
15 sec to idle down is pretty good.
Could be the IAC, (idle air control), valve just needs cleaning.
Depending on your high idle speed, might not be anything to worry about.
G
garyb6
westville nj
Ok Mike I will clean the iac it idles around 1800 then drops to 850 in 7seconds..
G
garyb6
westville nj
What's normal idling at 1800rpm before dropping off?
1997SCEBFEX
Northwest Panhandle
would have to ask how long between starts?
what's the ambient temp too?
any chance you have unmetered air entering somewhere, or a vacuum leak?
