How do I replace the pcv vavle?
Discussion in 'Transmission & Drive train' started by smo0othride, Jun 6, 2007.
  1. smo0othride
    smo0othride Full Access Members
    836
    May 26, 2003
    San Diego, CA
    I picked up a pcv valve at autozone and was wondering where it is and how to replace it? It came with a black, plastic L-shaped piece.
  2. pronstar
    pronstar Full Access Members
    324
    Jul 27, 2006
    Long Beach, CA
    i've got a 97 but I think yours is in the same place... Look at the passenger-side valve cover. It's the little tube that comes out of the top of it - pull it out. The PCV valve connects the tube to the valve cover, so you'll see it when you pull the tube out.
  3. mustangswan
    mustangswan Well-Known Member
    47
    May 21, 2007
    seattle
    Be warned that the PCV valves that are sold at aftermarket parts places are often very general in there applications and will either flow to much or not enough thru it causing oil build up in the intake, or a runablity problem. Ford PCV valves costs a little more but usually work much better. Spend a little now or a lot later, just my 2 cents worth.
  4. smo0othride
    836
    May 26, 2003
    San Diego, CA
    Thanks for letting me know this. I'll make sure to take back the generic one.
  5. green03
    green03 Full Access Members
    634
    Apr 28, 2006
    College Station, TX
    yeah and on the 03 you may actually have two hot water lines that are attached to the PCV valve. there is a big clip that holds the heating assembly to the valve. Remove this clip after pulling the valve out and it will be evident where to go from there.....
    Matt
Share This Page
