How To Change Rear Diff Fluid
Discussion in 'How To Section' started by nvycrmn, Jul 20, 2010.
  1. nvycrmn
    nvycrmn Full Access Members
    1,631
    Feb 15, 2010
    Springville, IA
    This is a quick how-to for changing your own rear differential oil. this will save you about $40 or so from taking it to a shop.
    1)loosen bolts (dont remove) all around diff cover and allow fluid to drain.
    2)after done draining, remove diff cover and set off to side.
    3)inspect gears for chipped teeth and look in carriage for debris. clean anything out that doesnt belong.
    4)replace new gasket or use RTV (black) and put cover back on.
    NOTE: if you are using RTV to create a gasket then wait 1hr after putting cover on to let dry.
    5)find fill plug and open (should just require 3/8 ratchet, no socket needed, and maybe 3" extension).
    6)Fill using owner's manual preferred oil. Trust me, its in there.
    FOR 01 EXPY WITH 9.75 REAR....75W140 FULL SYNTHETIC WITH OIL FRICTION MODIFIER...JUST OVER 3QTS.
    And there you have it. It just cost you $75 and about 1hr (drain time, wait time on RTV, and fill time) to do the same job that most places charge $110+tax.
    I will have some pics to follow.
  2. walnuts4x4
    walnuts4x4 Supporting Member Supporting Member
    34
    6,471
    Jun 18, 2009
    Watertown, NY
    you can also spray out the housing and gears with brake clean after the oil drains to clean it out better for a better visual for everything inside.... but good details on doing it.... wanna do mine LOL... wait were is DGray69 he can do it...:D
  3. nvycrmn
    1,631
    Feb 15, 2010
    Springville, IA
    i was gonna say, where is your mechanic? hahahah
  4. nvycrmn
    1,631
    Feb 15, 2010
    Springville, IA
    just in case any of you were wondering what your limited slip rear end looks like...
    [​IMG][/IMG][​IMG][/IMG][​IMG][/IMG]
    and this is what the fluid is NOT supposed to look like. This is what it looks like when you have water in there...not good.
    [​IMG][/IMG]
  5. panda24619
    panda24619 Full Access Members
    5,501
    35
    May 18, 2010
    San Diego
    what brand are you using? my dad said he would pay for the oil and gasket. and it is about $75 for everything. we can do that next weekend if you want while we do your short shaft.
  6. drtj
    drtj Active Member
    32
    Jul 18, 2010
    Ga
    nice write-up with pics
  7. nvycrmn
    1,631
    Feb 15, 2010
    Springville, IA
    thanks man. just thought i would let everyone know how easy it was.
    panda, i used valvoline from napa. it was $14 a bottle (buy 4 of them) and i only bought one bottle of 4oz modifier, but buy the 7oz instead. royal purple was super expensive. i bought the valvoline cuz it said compatible with ford...it shouldnt really matter what brand, as long as you buy the recommended weight. it should be on something like page 252 in your book. just look up fluids and it will tell you the page to find the levels and types. i believe most of the expys take the 75w140 FULLY SYNTHETIC.
  8. panda24619
    5,501
    35
    May 18, 2010
    San Diego
    that what mine takes. i just didnt know what brand you used. a lot of options out there. ill see what oreileys recommends.
  9. nvycrmn
    1,631
    Feb 15, 2010
    Springville, IA
    i called kragen (oreilly's) and they said they had some royal purple. its $17 a bottle. you can do this as cheap or as expensive as you want. but i think you are just paying for the name in my opinion.
  10. dgray69
    dgray69 Full Access Members
    659
    Dec 9, 2009
    upstate ny
    you had that wide open and did not put locker in.mmmmm great oppertunity to throw in that detroit, or arb locker. man thats rough. pull it apart again and at least weld that puppy. lmao
Share This Page
